March 5, 2021 at 2:19 pm
HaydarEzzedine
SubscriberI am simulating a interior configuration permanent magnet machine (machine type: adjust speed synchronous machine).
What is the default polarization direction for the magnets if I didn't specify it? And how can I specify the direction of polarization?
March 7, 2021 at 1:01 pmNavya C
The default magnetization Direction is along the positive x-axis.
That can be changed in the material properties for other Cartesian cylindrical or spherical coordinates.
Regards Navya
March 7, 2021 at 6:19 pmHaydarEzzedine
SubscriberThank you for your helpful answer.
I have a follow up question.
I split my magnets in Maxwell in the machine into two materials, same magnet but different polarization direction.
I want to ask if there is a way to assign different material for each magnet in rmxprt (before creating the maxwel design).
And if no, how does this affect the results in rmxprt under performance.
March 8, 2021 at 2:02 amAndyJP
SubscriberWOW! I did non know that. That is weird, because in HFSS the default magnetization is along Z axis. Kind of dangerous inconsistency.
March 8, 2021 at 2:07 amAndyJP
Subscriber@HaydarEzzedine materials are independent of designs. they hold all the data that can be used in any design in the suit.
March 8, 2021 at 10:47 amNavya C
You can only model what the template allows you in RMXprt. However, you can make the necessary changes after creating a maxwell design.
Depending on the changes you make to maxwell design it may differ to any extent from RMXprt result.
Regards Navya
Viewing 5 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2630
2110
1335
1110
461
