Define CONTA 178 Using command editor in workbench
    • velu.annadurai
      I am trying to define the GAP between two parts using CONTA178 in Ansys workbench 2019R2 but unfortunately, the script that I wrote is not executing.
      Could you have to look around and help to resolve this issue?
      attached workbench file for your reference.
      Vickieee
    • peteroznewman
      I made many changes to add displacement and fixed rotation so that the solver would run.
      I'm a beginner at APDL so I'm not sure how to use the R command to define real constants.
      You had this:
      R,_sid,FKN,FKS,GAP,X
      I changed it so it looked like this:
      R,_sid,FKN,GAP
      I did that because the table shows the items listed in the following order and I couldn't find an X in the table.
      Do Real constants have to be put in order?  I have no idea.
    • velu.annadurai
      Hello Peter,
      Good day!!
      Thanks for your reply.
      I hope so those r values are needed to be in order.
      trying a little bit in depth.
      Regards
    • peteroznewman
      I haven't tried it yet, but try this. It leaves a blank for START which you did not define and leaves off X which can only be provided in a Table, but is unnecessary, because you have the two nodes to provide the direction for the gap.
      R,_sid,FKN,GAP, ,FKS
Viewing 3 reply threads
