March 15, 2022 at 11:11 am
Sorte
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Good morning,
Could you please help me?
I can't define my domain outputs. It gives me the following error, "Flow outlet 10 is applied to a curved face. The flow direction will be applied in a uniform direction normal to the face". What should I do to define the triangles set as outputs? -
March 15, 2022 at 11:19 am
Devendra Badgujar
Ansys EmployeeHello Sandra Sorte
Let me check and get back to you.
March 15, 2022 at 12:56 pm
Devendra Badgujar
Currently Discovery takes only planar faces for CFD inlet and outlet specifications. It takes average normal direction for curved surfaces for velocity and mass flow rate. You will get this warning for curved faces. Exception: pressure BC is applied at curved face, since it is by default normal to surface at all locations.
I will make an enhancement request for this to be added.
Regards.
March 21, 2022 at 5:18 am
Devendra Badgujar
I have a correction on the above point I mentioned, this is currently not possible in Explore mode of Discovery but you can use Refine mode which allows the specification on a planar as well as curved face.
Please use Refine mode to define the triangles set as output for your case and you will not get that message.
I have also filed an enhancement request for this functionality to be added in Discovery Explore mode.
Apologies for the inconvenience.
Regards.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3648
2534
1745
1226
578
