July 24, 2018 at 3:11 pm
Valeria
SubscriberHello everyone
I'm doing design optimization with direct optimization tool, but I'm having trouble with a "Slice" in my geometry. A length is changing in my geometry during optimization and I want the slice to move accordingly. I parameterized the position of the plane I used to slice the geometry and I would like to link this parameter ("Plane4.FD1" in the attach) to the changing length Lc, as this plane is positioned 30 microns further from Lc so when Lc changes during optimization I want Plane4 to move accordingly (this is because I used this slice to mesh the geometry).
To be clear, Lc is 0.65 mm but has no units as it is imported from SolidWorks CAD, the plane is parallel to YZ plane and Offset Global x is -0.68 mm, i.e. -Lc-0.03 mm.
Does Anyone please know how I can set the dimension "Plane4.FD1" as -Lc-0.03 mm?
Thank you
Valeria
July 24, 2018 at 3:51 pm
Aniket
Ansys EmployeeHi Valeria,
Try Expression as P2*1[mm] instead of using Just P2 and let us know if that helps.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1345
1118
461
