Tagged: bearings, campbell, critical-speed, modal-analysis, workbench
March 11, 2021 at 4:27 am
timJiang
SubscriberDear all,eed help here pleasenI know it is achiveable in APDL, but how to do it in Workbench?nWhen simulating the fluid film bearing rotor, the stiffness and damping of the fluid bearing is not constant across the rotationary speed range. My aim is to get the campbell diagram and the critical speed.nMay I ask how to define the bearing parameters realted to the speed when using Modal in Workbench? For example, is it possile to define a table of rpm and bearing parameters to each bearing?nWishesnTimn -
March 12, 2021 at 6:13 am
1shan
Ansys EmployeeHello Array,nYou could input the stiffness vs rotational speed in a tubular format. After inserting the bearing connection, click on K11 (or any other K). There is an arrow to the right, click that and you would see a tabular option. This is available in 2021R1, I am not sure about the earlier versions.nRegards,nIshan.n -
March 12, 2021 at 7:11 am
timJiang
SubscriberHello @timJiang,You could input the stiffness vs rotational speed in a tubular format. After inserting the bearing connection, click on K11 (or any other K). There is an arrow to the right, click that and you would see a "tabular" option. This is available in 2021R1, I am not sure about the earlier versions.Regards,Ishan.https://forum.ansys.com/discussion/comment/110496#Comment_110496
Thank you sir for your kind repley.n
2066
1283
1096
459
