February 7, 2021 at 12:26 pm
Deus Ex Machina
SubscriberHello everyone, I am trying to define as input workbench parameter another output parameter in the same workflow (obviously another previously calculated case)nFor example: if I have output parameter P01 = 5, I want to use it in P07 as input parameter P07=P01. Right now I copy and paste, but I have about 100 points.nHow can I do this?nThank you very much.n -
February 8, 2021 at 4:59 am
Keyur Kanade
Ansys EmployeeI think this can be done through WB scripting. Please search on WB scripting on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
February 26, 2021 at 5:52 am
ramgopisetti
SubscriberHow about you type expression say for all Parameters . For all 100 parameters you can just type P01 in the expression field , it automatically copy the respective values into all parameters, so you left with one parameter to tune there after. nThat Said, you can use OPTISLANG Optimisation tool to bulk select the parameters and use the expression and it will applu to all selected parameters as follows n
Cheers,nRamn
March 4, 2021 at 2:24 am
Deus Ex Machina
SubscriberHow about you type expression say for all Parameters . For all 100 parameters you can just type P01 in the expression field , it automatically copy the respective values into all parameters, so you left with one parameter to tune there after. https://us.v-cdn.net/6032193/uploads/PHGW2VYWUZ65/screenshot-2879-29.pngThat Said, you can use OPTISLANG Optimisation tool to bulk select the parameters and use the expression and it will applu to all selected parameters as follows https://us.v-cdn.net/6032193/uploads/3SAH1EEPF6KX/image.pngCheers,Ramhttps://forum.ansys.com/discussion/comment/108247#Comment_108247
Thank you very much, that's what I was looking for.n -
March 5, 2021 at 1:09 pm
ramgopisetti
SubscriberThank you can you please make mine as answred in your side.nRam n
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2471
