DEFINE_INIT – Parallel
    • Dino
      Does DEFINE_INIT need to be parallelized in the UDF the same way DEFINE_EXECUTE_AT_END works or it works for both series and parallel the way DEFINE_SOURCE works i.e., no extra work in the UDF to convert from series to parallel?
      Thanks,
      Depends on what you're doing with it: what does the manual say?
    • DrAmine
      In general if threads and cell or face data are passed no need to parallelize. Make it run on not host.
