March 24, 2021 at 1:21 pm
Navsing
SubscriberHi,nnI am conducting a 2D simulation of water-vapor condensation upon a pipe wall. My simulation runs fine when using the default Lee's model in fluent.nnHowever I'm trying to implement a mass transfer phase change model from a paper which will provide more accurate results. I'm implementing this through the UDF macro DEFINE_MASS_TRANSFER.nnAlthough when I run the simulation with my mass transfer udf, it runs for approx 100 iterations and then the simulation starts to diverge. My UDF is listed here:n#include udf.hnnDEFINE_MASS_TRANSFER(liq_gas_source, cell, thread, from_index,from_species_index, to_index, to_species_index)n{nreal m_lg;nreal T_SAT = 373.15;nThread *gas = THREAD_SUB_THREAD(thread, from_index);nThread *liq = THREAD_SUB_THREAD(thread, to_index);nreal delta_t;ndelta_t = CURRENT_TIMESTEP;nreal lc = C_H(cell,gas)-C_H(cell,liq)nnm_lg = 0.;nif (C_T(cell, liq) >= T_SAT)n{nm_lg = (1./lc)*C_VOF(cell,liq)*(C_R(cell,liq)*C_CP(cell,liq)* fabs(T_SAT-C_T(cell,liq))/delta_t);n}nelse if ((m_lg == 0. ) && (C_T(cell,gas) <= T_SAT))n{nm_lg = (1./lc)*C_VOF(cell,gas)*(C_R(cell,gas)*C_CP(cell,gas)* fabs(T_SAT-C_T(cell,gas))/delta_t);n}nnreturn (m_lg);n}nnAny ideas of what could be causing this?.Many thanks!n -
March 24, 2021 at 1:31 pm
YasserSelima
SubscriberHello,nI am not sure if this is right or not, but I just noticed that m_lg is positive in both cases .. I believe that one case should be negative.nYassern -
March 24, 2021 at 2:26 pm
Navsing
SubscriberHello YassernYeah I didn't set this as I will only have condensation. But I did try to set m_lg for condensation negative and it still crashed at roughly the same amount of iterations. -
March 24, 2021 at 2:50 pm
YasserSelima
SubscriberI believe this is expected because of using high coefficient 1 ... Not sure how you can solve the problem but you can try decreasing the timestep, decreasing the under-relaxtaion factors and increasing the number of iterations in every timestepn -
March 24, 2021 at 3:50 pm
Navsing
SubscriberI have tried to decrease the timestep, relaxation factors and increase the iterations per timestep, still have the same problem.nWhat do you mean by using the high coeffficeint 1? Should I re-write the equation?n -
March 24, 2021 at 4:27 pm
YasserSelima
SubscriberI mean this 1nm_lg = ( 1. /lc)*C_VOF(cell,liq)*(C_R(cell,liq)*C_CP(cell,liq)* fabs(T_SAT-C_T(cell,liq))/delta_t);nnthe solver will keep transferring almost all the liquid to vapour in one iteration, then all the vapour to liquid in the next .... the solution is something in between n -
March 24, 2021 at 5:34 pm
March 24, 2021 at 8:16 pm
YasserSelima
Subscriberyes, I do understand the equation ... but what happens is when you have all the liquid in the cell evaporating, the temperature decreases ... this causes the solver to re-apply the equation and condenses all the vapour ... the temperature in the cell increases ... and so on. In addition to having energy balance between the cells, this becomes a a tough process for the solver to reach solution.nWhat happens in reality is ... the temperature increases, then part of the liquid evaporates until the temperature reaches saturation ... not all the liquid. So, the coefficient should not be 1 ... The default value is 0.1 .. you can increase it to 0.2 .. 0.5 ... but 1 will end up with numerical instability n
Viewing 7 reply threads
Trending discussions
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
