defined material (tensile and compression) contain negative slope – (softening)
    • murad Bsharat
      Greetings,
      My Inquiry:
      My objective is to establish a comprehensive definition for a concrete material capable of exhibiting softening behavior under both compression and tension loads, utilizing the Mander concrete model with damage plasticity. I am seeking guidance on the appropriate procedure to achieve this.
      NOTES
      1- Im have the data for the degrom (stress -strain)
      2- my project is analysis structure nonlinear time history  to get the maximum displacement ander seismic
    • John Doyle
      I am assuming you are using MAPDL or WB-Mechanical.  If so, please refer to the MAPDL Material Reference Manual on Geomechanics options.  The Menetrey-Willam material option offers softening in tension and compression (Section 4.11 of R2023-R2 MAPDL docs).
