Ansys Products
Ansys Products
Defining a fluid domain in an extrusion cut of a solid body
    • HusseinK
      Hello all,
      I have created a solid plate shown in the images below, I then extruded a channels cut the goes through the whole plate.
      I want to define these channels as fluid and have the plate as a solid body, I know that boolean requires two bodies to substract.
      Any ideas?
      Thank you!
      When you Cut you removed the bit where you wanted the fluid. Have a look at the options under Slice when the bodies are frozen.
