November 14, 2019 at 7:59 pm
November 15, 2019 at 10:31 am
mbeliaev
Ansys EmployeeHello,
please first check mesh size. Also from material properties I see you set BH curves for T11 and T33. If you would like to set it as air please set simple as values
November 15, 2019 at 11:41 am
camarajoe
Subscribert11 & t33 are BH curves for air. I simulated it again putting just 1 for t11 &t33 and got the same result -
November 15, 2019 at 1:19 pm
mbeliaev
Ansys Employeeair is linear material. It does not have BH curve (only theoretically)
have you checked the mesh in your model, is it fine enough?
November 15, 2019 at 5:05 pm
camarajoe
SubscriberIt is fine enough. Thank you for your input.
November 19, 2019 at 10:06 am
mbeliaev
Ansys Employeecan you please upload your model to some drive and share a link?
- Maxwell, HFSS or Q3D?
- Error
5364
3363
2471
1310
1018
