June 17, 2021 at 8:33 am
Dheeraj_Singh
SubscriberHello Team, For an component with multiple parts can we define different convection inputs for different parts in Explore mode? Regards, Dheeraj -
June 17, 2021 at 10:12 am
Subashni Ravichandran
Forum ModeratorHello Dheeraj Singh
I believe you should be able to do that. Are you facing any issues with this?
June 17, 2021 at 11:03 am
Dheeraj_Singh
SubscriberHello Subashni
Thank you for the quick response. Let me explain my scenario.
When we model a electronic component, all the parts are taking the same default convection value. In my case component is closed and convection should be applied only on outer surface. In general, when I assign heat input default convection is getting applied for all the parts(inside parts and outer surface).
How can I assign default convection to outer surfaces only??
PS: Need solution in Explore stage only.
Dheeraj
June 25, 2021 at 10:07 am
I'm not sure I understand clearly. Is there a vacuum inside or a different convection value inside the body? I suspect the model will be insufficiently constraint in such a case.
June 25, 2021 at 10:14 am
Dheeraj_Singh
Yes!! There appears a vacuum inside the domain. So only Convective rate should be applied on the exterior domain.
Dheeraj
June 25, 2021 at 10:37 am
Would you be able to share the model with us?
I have shared a Secure transfer link with you via email
July 1, 2021 at 10:23 am
I'm checking from my end. Let me run a few iterations from my side and get back to you on this.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2963
1449
1322
