June 20, 2022 at 10:08 am
June 23, 2022 at 12:43 am
Imtiaz Gandikota
Ansys EmployeeThe contraint definition is correct but note that for nodout option, you have to specify a node id and displacement of that particular node is extracted. Since you are interested minimum displacment of the entire part, use d3plot option instead of nodout and specify part id(s). If you have a shell layer on top of design part, extracting min displacement of this shell part might be better than using design part.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3720
2570
1783
1236
594
