Defining Materials in WB Mechanical
    • John Doyle
      Is there any guidance for using commands to define materials in Workbench Mechanical?n
    • Bill Bulat
      nANSYS Mechanical by default assigns a unique material id number (MAT attribute) to each part automatically and a unique number is also used for contacts/targets, springs, beam connections, surface elements, and other entities. The user cannot control the numbering that Mechanical does. A command object can be inserted under a part in the geometry branch that can make use of the material id number which the program makes available as ANSYS parameter named matid and then that parameter name can be used in a command object. Any part without a command object will use the material as set by Mechanical. So if you have many parts with different material for each, then you can put a command object under each part such as: nmpdel,all,matid ! this deletes all Mechanical material data for material id of matid nmp,ex,matid,3e7 nmp,dens,matid,0.283 nthen for another part: nmpdel,all,matid ! Mechanical knows that matid is different for each part nmp,ex,matid,2e7 nmp,dens,matid,0.25 nIf the material is nonlinear then add the desired TB commands for each part. nnIf you have many parts but only few materials, then you could use command objects like this: nmpdel,all,matid nmp,ex,matid,3e7 nmp,dens,matid,0.283 npart1_matid=matid ! needed to be used later - change part1_mat to a different name for a different material then any other part that uses this same material can just use this command object nesel,s,mat,,matid nemod,all,mat,part1_matid nesel,all nThere are many alternative methods to changing materials using commands but I believe these are the most common. As Mechanical does many operations internally you should definitely test all command objects carefully. Add a command object such as this under the environment (such as Static Structural) to check the material data: nMPLIST,ALL ! list all linear material data for all material idsn
