Defining supersonic outlet
    • imungan
      I would like to define the outlet bc as supersonic outlet. In user guide, noted that "Should the flow become locally supersonic, the specified pressure will no longer be used; pressure will be extrapolated from the flow in the interior. All other flow quantities are extrapolated from the interior." However when i changed the value of outlet pressure for my supersonic case, the exit mach number is changed.
      I will be pleased if anyone can clarify this issue
    • DrAmine
      At the outlet / near the outlet is the flow subsonic?
    • imungan
      Domain is entirely supersonic :)
    • DrAmine
      If you just check all other properties and velocity fields: any difference. I can think that it is a post-processing issue wrt Mach number.
    • imungan
      my case is hypersonic internal flow. So i am sure that my flow is remained supersonic throughout the domain. While i remain the pressure outlet as default, no error is occured. This may be correct but not sure
    • DrAmine
      As mentioned in my post if velocity field and temperature field and pressure field are not changing then I guess it is a post-processing issue. Please check that.
Viewing 5 reply threads
