October 23, 2018 at 9:49 am
rounaksingh
SubscriberHi, I am getting following error while running the a hfss simulation. G3dmesher is crashing
Definition Mesh, process mesh3d : Unexpected internal software error code -99 with module id 0.
The log file is below. It was run on a linux cluster with 1 node, 20 cores and 200GB of RAM.
Thanks!
October 23, 2018 at 9:45 pm
rounaksingh
SubscriberThis error was generated when I was running simulation in Electronics Desktop v18.1. When I ran the same file with Electronics Desktop v19.2, there was no error. The simulation seems to be running on the same computer.
The problem is unsure. May be a version-related problem which has been solved in the next version
December 31, 2018 at 12:34 pm
noamannaseer
SubscriberHi Rounak
I am facing the same problem, did you able to solve this error.
December 31, 2018 at 11:55 pm
rounaksingh
SubscriberHi,
I just upgrade the version to 19.2
- Maxwell, HFSS or Q3D?
- Error
2684
2124
1349
1136
461
