September 10, 2019 at 9:14 pm
rakesh_krishna
SubscriberHi,
I am quite new to using ANSYS tools. I have come to know that a layout designed in cadence can be imported into HFSS and cpactiances can be calculated between different layers. I am working on a PN junction charge simulation where the charge carrier profile, and depletion width changes with the applied reverse bias voltage.
Is there any way to define doping o carrier concentration to the dielectric layer? This would help me to calculate the junction capacitance over a reverse bias voltage sweep by extracting the charge carrier distribution at different voltages.
- Maxwell, HFSS or Q3D?
- Error
2688
2138
1355
1136
462
