November 2, 2018 at 3:46 pm
Dwaipayan1234
SubscriberHI,
I am trying to simulate axial flux permanent magnet machines with soft magnetic composite materials. I don't have any tutorial or video to explain how to define soft magnetic composite materials which is a material with nonlinear B-H curve and isotropic or homogeneous property. Please if anyone can suggest how to define the soft magnetic composite material, it will be very beneficial to me. Thanks
November 20, 2018 at 12:37 pm
mchristi
Ansys EmployeeThe B-H material properties for nonlinear, isotropic material (typically with units of Tesla vs A/m) must be obtained from the material supplier datasheet or by test.
For details on how to enter this information in Maxwell, please see online help topic: Specifying a BH Curve for Nonlinear Relative Permeability
November 20, 2018 at 3:59 pm
Dwaipayan1234
SubscriberThank you very much!
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
