deflection + torsion analysis of a pinion shaft
    • luiznogueirao
      I would like to analyse the deformation of a pinion shaft:
      Any suggestions?
      Best regards,
      Luiz
    • Aniket
    • luiznogueirao
      Hello Aniket,
      As input I have the forces acting on the pinion. The coupling transmits the torque of these forces to another component. This coupling should restrict the model only on the rotation around the axial axis of the pinion (transmitting only torque).
      I want to analyze the deflection of the shaft (deformations on the radial plans) generated by tranmitting the torque from the teeth to the coupling region.
      Best regards,
      Luiz
