LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Deformation of steel on sandstone in WB LS-Dyna ACT.
    • javat33489
      I'm simulating SPH drilling of sandstone particles using Mohr Coulomb in WB LS-Dyna ACT.
      Drill - rigid body.
      Nozzles on the drill are deformable.
      Steel properties:
      Sandstone properties:
      Why do my baits bend so much? They are much harder than sandstone. Drilling does not occur:
      Calculation time 0.001 s.
      I am using Displacement:
      Rotate 180 degrees and move 5 mm.
    • Ram Gopisetti
      Hi javat,
      rethink the material model for sandstone with some failure criteria , read the paper title "Numerical simulation of impact on pneumatic DTH hammer percussive drilling " by Changgen Bu et.al .
      cheers Ram
      • javat33489
        I read, thank you what I need.
        BUT I can't add that kind of stuff to Dyna ACT WB.
        1. I tried to add a MAT_JOHNSON-HOLMQUIST_CONCRETE snippet and PART card to link the rock to be drilled to the material, but the workbench gives me errors:
        Then I decided to add a section map, it didn't help either:
        How to add material snippet to Dyna ACT WB?
        I have a rigid drill. Rock / blank - sph - I want to assign the material to it through the map:
        2. Then I decided to add material to DYNE Prepost. And the calculation did not work again, the following error appears:
        But with a simple plastic material he thinks
    • javat33489
      I figured out the LS Dina ACT.
      The material snippet needs to be inserted into the geometry and not into the solver.
      BUT the material still does not work. When inserting a snippet:
      writes an error:
      If you insert without a TITLE, then the calculation does not start.
      But the LS-Dine postprocessor (black) still does not work. Error above.
