Deformation scale
    • davidk8
      I have seen many post about unrealistic deformation in the result, however, versions have changed and I couldn't find the button for adjusting the scale in display in the latest student version I believe (Workbench 2019 R3). Could someone tell me where can I find the button, or adjust the scale in viewing?
    • peteroznewman
      Here is a recent post.
    • davidk8
       Hi Peter,
      Is there a more simple way just to change the scale viewing instead of transforming into Parasolid files? Let's say I have a 200x10x10 mm beam with a maximum deformation of 0.1 mm, but the total deformation in the solution is showing like a 20 mm deformation instead of 0.1 mm, how can I change this display scale?
    • peteroznewman
      You click on the pull down and select 1 (True Scale) or type a 1 into the text box to replace the 15 in this image or the 20 you had.
      If this answers your question, please click the Is Solution link below (when you are logged in), or ask a followup question.
    • Teferi
      Hello Dear Peter,
      Many thanks for your kind help. Now it is fine. I made it True scale and there is no intersection of jaws now.
    • muzammilmustafa
      it was so helpful for me . . . I was so confused about irregular deformations , although the values were correct . . . thanku so much . . .
Viewing 5 reply threads
