DEFORMING as CYLINDER in Dynamic mesh
    • shaheen wahab
      Can anyone explain to me how "Deforming as Cylinder" works? I know the cylinder radius. For the Cylinder origin, I need to use the center of the cylinder (which is the center of the circle, as the cylinder is made by extruding the circle in the Z direction) How do I put the Cylinder Axis? I am confused with this. Do I need to put the plane in which the Cylinder axis lie or something else?
      I would be really grateful if anyone could explain this to me.
      Shaheen
    • Keyur Kanade
      as circle is extruded in z direction, cylinder axis would be 0 0 1.
      hope this helsp.
    • shaheen wahab
      Ohh perfect. Thank you so much Keyur
    • Keyur Kanade
      welcome!
      please mark this as 'is solution' to help others on forum.
    • shaheen wahab
      Dear Keyur,
      Thank you so much for your help. It worked!
      With regards
      Shaheen
Viewing 4 reply threads
