Deleting all the files in the directory with apdl
    • kh_d
      Hello everyone,
      I want to use DesignXplorer to study the change in material properties. I have to save all the files in each run because they are required for substructuring. There are going to be more than 2000 runs, and I want to know if it is possible to delete all the files after each run not to have that many folders saved.
      I have found /DELETE command but that seems to work only for a single file with a certain extension.
      Any hints about how I can solve this problem are appreciated.
      Thank you very much in advance.
    • peteroznewman
      $143 at newegg.com
