Demagnetisation Curve Help …
    • shrek
      Hi
      I was trying to obtain the demagnetisation curve of a magnetic material using Ansys Maxwell.
      How to go about it, any inputs would be great!
      Thanks
    • mgardner
      Generally, you have to provide the material data.  You will probably need to get that data from the manufacturer.
      However, if the material is already defined in one of the built-in libraries, you can find its B-H curve when you view/edit the material.
    • shrek
      What is it is a magnetic material with hysteresis loop.andys maxwell feature says I can include hysteresis curve as material property.any help on how to do that?
