Demagnetization link of permanent magnet synchronous motor analysis
    • UsamaKhan
    • icellb1
      Hi From the error message, the geometry in your two designs are not equivalent. May I ask how you created geometry for the 2nd design?
    • UsamaKhan
      Hi
      I created one design first then made a copy of that design.
    • UsamaKhan
      One thing i want to mention is that first i created through RmXprt then i made modification according to my requirement !
    • icellb1
      Hi May I know which version of AEDT are you using?
      Also, could you describe in detail (adding screenshots would be better), after you copy+paste your source design to become the target design, what changes you made on the target design? Materials, boundaries, mesh operations, excitations, added geometries (planes, lines, etc), changed coordinate system, optimetrics, etc. ? Better to include everything you did.
      Also, could you show screenshots for how you set magnetization computation in source design, and how you setup permanent magnet field excitation in target design (include screenshots for general, variable mapping, and object mapping tabs).
      Also just want to double check or confirm with you that you copy+paste the whole design rather than copy+paste the geometry from one design to another.
    • UsamaKhan
      Hello I am using following version
      I just copy whole design and paste it. Following are screenshots it might helpful:
      Now the Target design:
      while setting permanent magnet demagnetization link:
      I press ok in above tab:
      Press ok and start simulation
    • UsamaKhan
    • UsamaKhan
      Respected Sir/Madem
      I waiting for your response ?
      By the way i want test demagnetization effect as shown below:
    • Supriya
      Do you get the result that how to do demagnetization
    • Supriya
      Do you get the answer??
    • hardikjp322
      please help me to know how to setup demagnetization in motor?
      please suggest any tutorial if available.
      i review ansys help document but didn't get the idea
Viewing 10 reply threads
