Density based solver diverging near walls
    • Ashwin Subramanian Murugan
      Hello all, The inlet of my geometry has a supersonic nozzle. I am trying to simulate flow through it in steady state initially and then later in
      unsteady conditions.
      With the density based solver I was able to get a steady state solution. When I started to run the transient solution , my results start diverging near the wall. Without the inflation layers, it is not diverging.
      However, when I use the pressure based solver  I am able to get really good results with inflation layers as well. I want to recreate the results using density based solver as Mach number in my flow exceeds 3.
      Please let me know how to fix this issue.
      I will attach pictures
      Solver settings for steady state simulation
      Courant no - 5
      when I start the transient sim, after some iterations: (timestep 1e-6 s)
      1. How do I prevent this from diverging as shown above in transient sim?
      Thanks
      Forum Moderator
      Duplicate https://forum.ansys.com/forums/topic/diverging-results-with-density-based-solver-2/
      Hello, can anyone please help me with this problem?
