Density Solver – Ejector
    • SilverRD
      May I kindly ask for your help. I am doing a simulation for an ejector the details are...
      Solver: Density based.
      Model: Transition SST (4 eqn)
      Material properties: R1234ze (Density, Cp, thermal conduction, viscosity > real gas - nist).
      Formulation: Implicit
      Flux Type: Roe-FDS
      Spatial Discretization
      Gradient: Least Squares Cell Based
       Flow: Third-Order MUSCL
       Turbulent Kinetic Energy: Third-Order MUSCL
       Specific Dissipation Rate: Third-Order MUSCL
        Intermittency: Third-Order MUSCL
        Momentum Thickness Re: Third-Order MUSCL
      do i need to run the simulaiton more than 42250 times?
    • SRP
      I suggest you to try FMG initilization. Flow convergence can be accelerated if a better initial solution is used at the start of the calculation. The Full Multigrid initialization (FMG initialization) can provide this initial and approximate solution at a minimum cost to the overall computational expense. other you can try using real gas property table (RGP).
      You can refer to fluent user’s guide for more on FMG initilization: 33.10. Full Multigrid (FMG) Initialization (ansys.com)
      Thank you
    • SilverRD
      Hello! Is there any way to open the link you provided?
    • SRP
      Please refer to this forum discussion: Using Help with links (ansys.com)
      Hope this helps you.
      Thank you.
    • SilverRD
      Hi! I followed your suggestion to use fmg initialization. however, there are some error. May i kindly ask how to fix these errors?
    • SRP
      Such error mostly occur due to bad mesh. Can you please share your mesh statistics?
      Thank you.
Viewing 5 reply threads
