Dependence between bolt adjustment and Sweep SIze of bolt
    • Tim Dietl
      Hello everone, why is the value of the bolt adjustment getting higher, when I increase the sweep size of the bolt? Shouldn't it approach an specific value?
      Thanks in advance!
    • Rahul Kumbhar
      Do you mean if you increase the elements along the length, the bolt tool in result shows higher adjustment value?
      • Tim Dietl
        Do you have an idea why this happens? Could the stiffness change somehow?
    • Tim Dietl
      Yes, exactly.
