STEM
STEM
dependence of pressure on height/depth from sea level??  ?
    • prajput
      Hello Friends,
      Is there any dependence of pressure on height/depth from sea level? ?
    • Akismet
      Yes. The variation of pressure in a fluid at different height is due to gravity and is called hydrostatic pressure. It is defined as:
      p - p0 = rho * g * h
      where
      h = z - z0 is the height from the reference point 0 (arbitrary)
      p0 is the pressure at reference point 0
      rho is the fluid density
      g is the gravity (assumed constant)
      BTW if you are interested, check out this free course by Ansys, that talks about Fluid Statics in detail:
      https://courses.ansys.com/index.php/courses/fluid-statics/
