June 13, 2020 at 8:31 am
BadDan2012
SubscriberHello,
I want to do an optimization of the geometry for imported CAD data with ansys maxwell. I managed to get the proper parameters with the prefix DS_ transferred to workbench. In the Maxwell Simulation I put a local variable for my DS parameter and know i want to optimize the torque, which i put as an output. Now when I start an optimization over Workbench it lists my DS variable and my local variable from Maxwell. But the design points for both variables are different: for example DS_radius=150, and local_radius=145. How can i say that they should be equal? Or do I have to do the optimization directly in Maxwell?
The error message is:
(DP 1) Maxwell > Parameter 'local_NUTHOEHEROT' are mapped to variable 'A1@DS_NUTHOEHEROT' in source design 'Geom'. Workbench passed in '11.5' for source design, but passed in '10' for target design. Result may be incorrect. (2:59:41 Jun 12, 2020)
- Maxwell, HFSS or Q3D?
- Error
3862
2639
1859
1254
600
