Ansys Products
Ansys Products
Design Explorer – RSM
    • alitabei
      Does design explorer work with hpc cluster?
      I get this error:
      Looks like the only way is to change the update option to "run on the foreground" (and not on RSM).
    • tsiriaks
      Hi Ali,
      If you submit the 'update design points' then yes, each 'Solution' cell must be set to foreground solve because the design points (Parameter Set) itself is already solved in background via RSM.
      See here for more details.
      1. Use 'update' for certain system/module
       https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb2_help/wb2h_submit_solutions_rsm.html
      2. Use 'update design points'
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb2_help/wb2h_updatedprsm.html
