April 23, 2022 at 10:26 pm
Tyler_0031
SubscriberHi everyone,
I am currently working on a simulation for my senior design project, and was wondering if anyone would be able to direct me in the right direction.
I am still super new to Ansys fluent, so I am at a point with this where I don't know how to move forward.
The CAD person in my group sent me the model for our aircraft, I tried importing the model as a .STEP, .IGS, and .x_t, all providing me with a "face-face:" inconsistency warning/ "edges touch" warning.
Is this a problem with importing the geometry on my end? Or is this more likely an error that design modeler is picking up from the original CAD model?
My goal at the moment, is to generate a subtraction Boolean. Which I am also having issues with because I can't seem to figure out how to make this one body.
If I were to fix the face-face inconsistency, would I then be able to perform a subtraction Boolean for my whole model? Or is there a way to just move forward with these warnings?
Just super lost right now, any suggestions are greatly appreciated.
Here is the current display with warnings:
April 27, 2022 at 8:33 amNaresh Patre
Can you try importing the geometry in SpaceClaim and then use tools like Stich, Gaps, Missing Faces, etc. from the Repair tab to convert the geometry into a single solid body?
- Naresh Patre
Viewing 1 reply thread- The topic ‘Design Modeler Face-Face Inconsistency’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Local mesh refinement with targeted edge lengths at specified areas
- Fluent Meshing Batch Mode – Problems workflow commands
8808
4658
3153
1680
1470
