3D Design
3D Design
Design modeler, sketching
    • kaitova
      Hi, I know that everybody uses Space claim already, but if somebody can advise me, what is the base sketch in design modeler? I cant make  a sketch for some reason.
      Thank you
    • Aniket
      It seems like you are using a sketch instance:
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_dm/dm_sketchinstances.html
      Use the normal sketch instead.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_dm/dm2dSketchStatus.html
      -Aniket
    • Keyur Kanade
      For creating sketch, select any plane and then shift to sketch mode.
      Keyur
