June 3, 2019 at 7:34 pm
jainanup27
SubscriberWhile generating DOE for Response Surface optimization is there any way that the values of the DOE generated has only two significant digits. For eg. assume p1 paramater has lower bound of 0.3 and upper bound of 0.5. I want the DOE values in between 0.30 to 0.50. The ANSYS Design Exploration tool gives DOE points like 0.3569, 0.4897, 0.3487 etc. I want those values to be like 0.35/0.48/0.34 etc i.e. only two significant digits. The reason being if I have three/four significant digits the DOE generates two points that differ on the third significant digit like 0.345 and 0.346 which is of no use to me and unnecessarily increases my sample space -
June 11, 2019 at 10:07 am
DrAmine
Ansys EmployeeUnder Tools>Option>Appearance reduce the number of signification digits to minimum which is 3.
June 11, 2019 at 6:36 pm
jainanup27
SubscriberThanks for your reply!
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- Errors about integrate executable into ANSYS Workbench using ACT
- Optislang workbench add-in
- Parameter relationships for Optimization
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3930
2649
1865
1272
610
