July 16, 2018 at 8:26 am
Valeria
Subscriberhello everyone
I'm doing design optimization with direct optimization (first screening then MOGA) but Ansys gives error when I set as input parameter a length: I think it happens because this length is associated to a SLICE in design modeler, but I need the slice to make a structured carthesian mesh.
Does anyone know how to fix it?
July 16, 2018 at 11:42 am
SubscriberHello Valeria,
ANSYS should be able to parametrically move the location of a plane or surface used to slice geometry in DesignModeler and automatically update that from Workbench. See this example from your other post.
Can you attach the example as a Workbench Project Archive .wbpz file to your post so we may take a look?
July 19, 2018 at 5:58 pm
Valeria
Subscribersorry Peter, but how can I attach after I have the file in the format you say? here I can only insert links or images
July 19, 2018 at 6:17 pm
SubscriberAfter you post, an Attach button appears on your post. You can use that.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2080
1293
1106
459
