September 21, 2018 at 8:36 pm
September 21, 2018 at 10:37 pm
Sandeep Medikonda
Ansys EmployeeIf you are looking to create a beam or surface like structures, you can always parameterize the thickness and use design explorer or Optislang even....
Also, the appstore currently has 2 free apps that can generate honeycomb structures, I haven't tried these but you might be able to parameterize in there as well if you have the xml script:
Alternatively, you can also pattern and parameterize in SpaceClaim or DesignModeler:
So, a quick google search illustrates someone analyzing a structure like this:
Alternatively, If you want to then determine the optimum geometric parameters for a desired structural behavior(Stiffnesses--Usually the end goal). Although several homogenization techniques can be used, they are be primarily calculated based on kinematics:
- Based on kinematics: 6 different solicitations are applied to the unit cell: 3 tensile tests and 3 compressive tests, and resulting force reaction are post-processed and the effective properties of the RVE calculated.
Homogenization is a technique most people use to analyze such structures, peter had provided a very good explanation in this discussion.
Sandeep
September 21, 2018 at 11:22 pm
balsaidi
SubscriberThanks Sandeep!
Can you please articulate what you wrote, If you want to then determine the optimum geometric parameters for a desired structural behavior(Stiffnesses--Usually the end goal).
Yes, I need to determine the optimum geometric parameters to meet some desired structural behavior. How can I do it?
Bashir
September 22, 2018 at 12:57 am
Sandeep Medikonda
Ansys EmployeeWhat I meant is typically using periodic boundary conditions, you first subject your unit cell to different loading conditions while parameterizing the geometric features. You then back-calculate the stiffness of the unit cell in different directions based on the force-deflection response. My understanding of homogenization is based on what you would do for composites, where let's say you are studying the effect of an angle between the 2 fibers on the overall stiffness of the RVE.
So this might not even be required for you here since you are dealing with just one homogenous body. Just build your structure with the dimensions you want, parametrize the features of interest using DX and look at the probes of the reaction forces vs displacements.
Sandeep
September 22, 2018 at 3:31 am
balsaidi
SubscriberSandeep,
I never done it before. I would be grateful if you could share/create document to guide me through the process of performing such study. Please, you can create simple geometry and perform these processes and I will do it on my structures on the same manner.
Bashir
September 22, 2018 at 11:10 am
SubscriberBashir,
Here is my video which specifically targets creating your own parameters in SpaceClaim and exercising them in Mechanical.
September 23, 2018 at 6:12 am
balsaidi
SubscriberThank you Peter and Sandeep for your help!
Bashir
October 4, 2018 at 2:49 am
Sandeep Medikonda
Ansys EmployeeHi Bashir,
I think the newly introduced Material Designer tool might be better suited for your study. Please see this discussion.
Sandeep
October 4, 2018 at 11:01 pm
balsaidi
SubscriberThank you Sandeep!
Bashir
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2524
2066
1279
1096
457
