December 5, 2022 at 7:07 pm
Saif Khalid
SubscriberHow can I design a switched reluctance motor and make a change in its geometry and then make an improvement in the geometry parameterss in order to improve its characteristics
December 6, 2022 at 11:42 am
Ansys EmployeeCarefully.
With any simulation it's a case of understanding the physics, and that may require you to build a simple model of the device. Once you can see the results, use your knowledge of the device to implement design changes. Or, use a parametric sweep over dimension/property/boundary condition and an output parameter to create a response surface and hunt for the "best" design.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2532
2066
1285
1104
459
