January 24, 2023 at 1:41 pm
Lara Hijazi
SubscriberHello,
I am designing an antenna. I am trying to optimize the variables in the circuit design to get a minimized value of S11. But, the optimization technique (I tried differnt methods) is not working for doing so, what are your recommendations for optimizations of variables in the circuit design? or do you think there is a problem in the HFSS design (by the way, I have no errors in the HFSS design)?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
