3D Design
3D Design
Designing the 2D distributed material
    • jackhero
      I would like to ask for some guidance on designing the random distributed rods in 2D. Previously I had help from @Peter for designing the random material in 3D (attached here). On my system the processing takes long time for 3D simulations, therefore I intend to carry out 2D simulation on ANSYS workbench for bending. The intended 2D geometry of the beam is shown below,
      Will it be possible to design the geometry of the random distributed rods in 2D so that I can use them as reinforcement in the beam? I do not have expertise in matlab coding if someone may assist on this issue would be helpful.
       Thank you
    • peteroznewman
      Hello Jack,
      Background for other members, you are referring to this discussion.  Separately, Sarah asked a similar question in this discussion and you asked her for the matlab code at the end.
      I don't know the answer to your question about 2D model. I hope other members reply.
