3D Design
3D Design
Designing two bodies in one another in ansys design modeler
    • jacks3215
      I am working on ansys workbench 16 design modeler. I would like to request for geometry of pullout bar in a cube. I tried to draw it by myself but i couldnt figure out how to draw the bar embedded to a certain length in a pre drawn cube. It would be of much help if someone could help me on it.
      I have attached a sample image of the desired geometry.
      Rectangular cube size say 5x5x10 mm
      Bar embedded size 1 mm
      Bar free length can be 2 mm
      Thank you
    • jacks3215
      Thank you
    • peteroznewman
      There was one last step to have the rod embedded in the cube. Add a Boolean from the Create menu and subtract the rod (tool) from the cube (target), and keep the tool (rod).
      Are you using ANSYS 16.0 or 16.2?
    • jacks3215
      Thank you for your reply.
      I am using ANSYS Workbench 16.0
    • peteroznewman
      I have ANSYS 16.2 installed (as well as 17.2 18.2 and 19.0). If you can upgrade to 16.2 then I can send you files.
    • jacks3215
      Can you please send files for ANSYS 19.0?
    • peteroznewman
      Here is your bar in a hole in a block.
Viewing 6 reply threads
