3D Design
3D Design
Designmodeler : Filling tunnel
    • hjmn
      Hi, I'm new to DesignModeler and I want to fill the tunnel which has two pipes in it to extract a volume to mesh on. I received a scanned model(Revit) by using 3D scanning devices and I moved the file to Ansys DesignModeler. I think it contains several gaps between the walls considering the file was scanned by a device. I used the fill function to extract the volume but it doesn't work out. I've been trying for weeks to solve this...to fill the gap or re-draw the whole model... Is there a clear method to extract a volume to create a mesh with an imperfect model? Or how can I modify this model properly?
    • RK
      To use the volume extract, you will have to make sure that there are no gaps, which would otherwise lead to leakage during the volume extraction process. First, I would strongly suggest you to fix the geometry. I am not very familiar with Design modeler but in SpaceClaim, there are tools to Repair the geometry. You could use them to fix it and extract the volume.
      Second option, which I am not very sure it would work but worth giving it a try. Create a whole solid representing the volume of the model and then do a boolean operation to subtract the internal features.
