Ansys Free Student Software
Designmodeler not starting up
    • adityaa99
    • Ruturaj Gavali
      Hey !
      Could you please directly attach images to your post instead of attaching the file. We aren't allowed to download any files.
      Thanks!
      For more information, check out the following links:
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
    • adityaa99
      @rgavali
      as you asked
      thank you
    • adityaa99
    • ANSYS_MMadore
      Can you try renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old, where vXXX is the version you are running? Also, please open a Windows command prompt and run "dxdiag" and send screenshots of each tab from the dxdiag utility that opens.
    • adityaa99
      Thanks for helping i did not do what you asked. Instead I downloaded it on a different system and it worked on it. must be an issue with my computer.
      -Aditya
Viewing 5 reply threads
