May 27, 2022 at 12:19 pm
May 31, 2022 at 9:31 am
Chinmay T
Can you please let us know how did you design this coil?
You can use the Ansys toolkit for designing the coils.
Try connecting the coils using the same cylinder objects present in the design.
Click on the error message in the Message Manager window to see which object is causing the error. You can also try the healing option to overcome this error.
Please go through "Setting the Healing Options" from HFSS Help document for more information.
Thanks Chinmay
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
