February 21, 2022 at 4:22 pm
Kirankumar
SubscriberDear friends
I am simulating port injected si engine, what is the minimum specification of laptop required to simulate the process?, because I did my simulation using dual core(Intel) with 4gb ram laptop but my simulation stopping in the midway by showing mpi dead lock error, i think this error is due to low ram availability. Please suggest me how to overcome this problem
Thank you
February 22, 2022 at 6:17 amVinayak Vipradas
Minimum Hardware requirements:
Processor(s): Workstation class
4 GB RAM
25 GB hard drive space
Computer must have a physical C:/ÔÇØ drive present
Graphics card and driver: Professional workstation-class 3-D
OpenGL-capable
Please see if the following discussion helps:
MPI Deadlock issue while running FORTE in cluster. ÔÇö Ansys Learning Forum
Regards Vinayak
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
April 24, 2022 at 5:49 amjhonibraham
SubscriberAnsys Hardware Requirements:
64-bit Intel or AMD system, running Windows10.
A dedicated NVIDIA GPU card (Quadrorecommended,GeForce supported) basedon the Kepler, Maxwell,Pascal, or Turing architecture. Maxwell 2000 or better is strongly recommended.
At least 4GB of video RAM (8GB recommended) on the GPU.
More than 2 Physical CPU Socketsin a System
Multiple Machines Running in a Cluster
Simultaneous Users on a Machine(Remote or Local)
A minimum of 1TB is recommended for the installation and use of your Ansys software.
Ansys Innovation SpaceTrending discussions- 2022 R1 What’s New PDF/PPTX?
- Prms/ pmean
- separation based debonding,CZM parameters
- Hydrodynamic diffraction and response
- The simulated results of microstrip patch antenna does not match the online example
- Desktop/laptop specification for Ansys forte
- how to simulate piezoelectric patch on ANSYS workbench ?
- Heat simulation – change source wavelength
- Mudjere
- Meshing/Simulation problem
2600
2088
1319
1108
459
