May 19, 2022 at 5:21 am
emrehangursoy
SubscriberHi everyone,
I want to export the result obtained from the Chart. I am creating a Chart and I can see the value on the y-axis. Also, I can see the min and max value Chart-->Data Series-->>Series 1 (right click)-->Statistics. But, when I exported the Chart x-axis and y-axis values, the file that has the .csv extension is not compatible (Surface Nusselt Value is come as scientific. I want to as fixed.
May 19, 2022 at 7:14 amNikhil Narale
Ansys EmployeeHello,
Can you post these images directly into the comment section and not attach it? Ansys employees are not allowed to download any attachments from here.
Viewing 1 reply thread- The topic ‘Desultoriness between Chart and Export File’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
