February 11, 2021 at 10:30 am
alimuradpasha
SubscriberHi, nI model a hydraulic system in Twinbuilder using Modelica. I have problems in my system and I want to get detailed information about these problems. But in Twinbuilder it throws an error without showing any detail. But for example in Dymola more details about the error can be observed. For example the error in Dymola is like: nModel error - differentiated if-then-else was not continuous: (if time < 0.050724637681159424 then 0 else Sine2.amplitudesin(289.02652413026095(time-0.050724637681159424)+Sine2.phase)) Value jumped from 0 to 0.00556683.nIs there any way to get more detail about the error in Twinbuilder like Dymola?nBest regardsnSenol -
February 11, 2021 at 5:35 pm
Jose Luis Gonzalez Hernandez
Ansys EmployeeHello,nnTo access the detailed information, please under Transient Analysis select Default options. nIn the next window select New . Go to General tab and under Advanced Logging Info Select All. This will generate an advanced log for you.nTo access that log, open the results folder and search for the name of your design, you will see a folder named Advanced Logs.nnRegardsnJose-Luisn
- Changing of font size
- System Coupling
- 3D ROM in workbench
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- HARDWARE COMPATIBILITY
- System Coupling
- ANSYS Direct Optimization
- When I open the Electronic Desktop, Twin Builder auto opens
5290
3311
2471
