January 25, 2021 at 11:23 pm
cluna
SubscriberJanuary 26, 2021 at 2:30 pmANSYS_MMadore
Ansys EmployeeArrayWhat version are you running? Can you open a Windows command prompt and run the command dxdiag and then share screenshots of each tab of the utility that opens?nJanuary 27, 2021 at 5:16 amJanuary 27, 2021 at 5:21 amcluna
SubscriberInterestingly, I discovered that I have another monitor, and I do not have this loading error with the Details View pan on my other monitor when it is connected to my HDMI port, only on my laptop. This error occurs on my laptop whether or not another monitor is connected. That will have to be my work around if this issue continues I suppose. I would like to resolve this though. nJanuary 27, 2021 at 4:04 pmANSYS_MMadore
Ansys EmployeeHave you tried modified the resolution to different options on your laptop display?nJanuary 27, 2021 at 9:35 pmcluna
Subscriberchanging the resolution does not solve the problem.nFebruary 14, 2021 at 5:56 pmANSYS_MMadore
Ansys EmployeeArray This is the only other suggestion for working with 4K/UHD displays as they are not currently supported.n1.Change the High DPI settings under compatibility settings. Right click on Workbench shortcut or start menu icon -> Properties of workbench > Compatibility > Click on Override high DPI scaling n2. Change the Scaling performed by option to System(Enhanced)n3. Could also try the option: Under Compatibility select Disable display scaling on high DPI settings.nnViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5340
3345
2471
