March 17, 2021 at 2:00 pm
NLev
SubscriberIs there a script or function that can check whether a point in the simulation is within a non-rectangular element (cylinder, ring, triangle, polygon, custom...)? Could this be implemented?n -
March 17, 2021 at 5:15 pm
Kyle
Ansys EmployeeHello Array,nThere is an inpoly command that can be used to check if a point is inside a polygon object:nArrayI don't think there are script commands for determining if a point is inside different objects, however. For the other types of objects, if they're simple geometry objects (circles, cylinders, triangles) you could probably come up with a mathematical expression for determining if a point is inside the object. Of course, you could also just create these shapes from polygon objects as well.n
Trending discussions
- Error on Lumerical device
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
