May 10, 2023 at 3:36 am
Kavi Pradhap M
SubscriberConsider a plate 10 x10 x 2 mm made of some anisotropic material modeled in ansys and material propertes given using ansitropic elastic contanst (21). Since the properties of the component vary in all direction how to find material propeties in a specified location such as 5 x 5 x 2 mm from orgin?(considering any of the plate corner as orgin.)
Thank you in advance
Regards
kavi
May 10, 2023 at 10:05 am
Ashish Khemka
Ansys EmployeeHi Kavi,
Try selecting the element at that location and then issue elist command. ELIST command lists the elements with their nodes and attributes (MAT, TYPE, REAL, ESYS, SECNUM, PART). You will see the information in the Solver Output.
Ashish Khemka
May 10, 2023 at 3:50 pm
Kavi Pradhap M
SubscriberHi,
Thank you for replying,
I have tried the above method. it will give the mateiral no. (like mateiral no. 1 or 2 )etc. In isotropic material the propeties are equal in all the directions. But i am trying with anisotropic mateiral, in which material propeties is different all the location. once the material properties are defined, how to check the value for a particular node or location
Regards
kavi
May 15, 2023 at 9:05 am
Kavi Pradhap M
SubscriberHi Ashish Khemka,
Greetings of the Day
Any update on this,
Regards
kavi
3419
2473
1310
1022
