Determining Force acting on a 90 deg bend
    • i.tamunodienye2
      Hello all,
      Please i want your contribution concerning this subject.
      If you want to determine force acting on a bend, do you set it directly from Fluent? If so, how it is set up.
      If this is not the case, could anyone explain procedures to follow.
      Thanking you in advance.
      Regards
      If you mean the fluid force, calculate (post process) in Fluent.
    • i.tamunodienye2
      Hi Rob Yes, i mean the force on the wall as a result of the fluid impact.
      The set-up please. Any tutorial please help me.
      Thanks
      Impact as in jetting or just the normal pressure field? For the latter have a look at the tutorials that come with the Help system.
    • i.tamunodienye2
      Ok i will check out the tutorial for the pressure field.
      Impacting as in jet will be another option to look into. Could you please also direct me where to go.
      Thanks
      Click on "Help" in Fluent. Any of the Help buttons in Fluent will get you started.
    • i.tamunodienye2
      Ok i will.
      thanks
Viewing 6 reply threads
